Gettings sparks when doing Ze, of Pfc | on ElectriciansForums
Discuss Gettings sparks when doing Ze, of Pfc in the UK Electrical Forum area at ElectriciansForums.net
J
Jel
Hi,
Recently i tested to places, and when i carried out the above tests at one property i was getting a spark where the earth clamp joined the sheath off the main supply.
I also got it on a TNC-S system where it was sparking half way down the main SWA supply, and smoke was coming out of it each time?
What does this mean as i am very concerned?
When was your meter last calibrated?
give the manufacture a call and ask them - they are the only ones who can give advice on this!
What make is it so others can be aware?
Poor connection on the sheath and damaged SWA at a guess. Did you isolate and check for damage, loose connections etc?
I could not Isolate, it was the supply from the Street coming into basement.
The first one did have very high Ze and i redid the clamp and got the reading down to a satisfactory level, however it did not eliminate the spark.
The metre is a megger mft1553, and it calibrated.
No has not sparked anywhere else.
The basement did smell damp, it was in a cafe, bags of rubbish and rat droppings, you can imagine the smell.
The other place was in a cupboard and the clamp did have a lot of grease around it?
Reply to Gettings sparks when doing Ze, of Pfc in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
