GEWiSS Isolator help... | on ElectriciansForums
Discuss GEWiSS Isolator help... in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Luton
Hi, I'm currently testing a factory and having difficulty removing an isolator cover to test a circuit. Usually, it's just a case of switching off and removing screws however the cover doesn't seem to want to come off as if the mechanism is stuck but it definitely is working as you get a real positive lock and before I break it or change it needlessly is there something silly I'm over looking lol
Thanks Lewis
[ElectriciansForums.net] GEWiSS Isolator help...
Yes remove those two screws and it will come apart, the rest inside should stay put if the two plastic fixing tabs top and bottom on the rotary part haven't broken off and they do! Also you will find that the terminal screws are ridiculously small and fragile.
I hate those isolators with a passion. If I ever quote for a job with those installed I will always quote to replace them, yes I hate them that much!!
Sy
You need to switch the isolator off to test it.
Looking at it, the four corner screws would come out, the lid would come off, but the yellow part would stay as it’s mounted on a din rail
It's sods law that if your being watched and your trying to open something for the first time you'll invariably look a chump. If working alone it will all go perfectly and logically. Quite a long time ago I was trying to work out opening a Sangamo time clock for the first time, I was totally over thinking it and the pins were a bit rusty. A plumber had to show me how to do it!!!
Anyway, working on those isolators is nearly always an unpleasant experience and before touching one I try to have a spare unit handy. I concur that you only have to sneeze near the terminal screws and they snap.
Probably breaks some H & S rules, but, with the addition of a couple of short self tapping screws, it's possible to reassemble these switches so that the cover can be removed without all the rotary part dismantling
Not actually a requirement, but it's good practice to include a banjo under the SWA gland nut, and tie it into the cpc..
Reply to GEWiSS Isolator help... in the UK Electrical Forum area at ElectriciansForums.net
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
