ghosting on leds | on ElectriciansForums
Discuss ghosting on leds in the Australia area at ElectriciansForums.net
J
John Bunning
hi any you guys had this problem. fitted 6 off inset leds in a hallway. look fantastic but when switched off there is a small glimmer from the leds .bit like ghosting on a neon screw driver.had a look found when i remove the 2 way switch and cable all ok.
tested the cable and switch perfect.its in an old house so i used the old steel conduit in the switch drop .is it possable cable is inducing a small voltage in the off position to the other cable ?
apprecate any ideas thanks jb
Reply to ghosting on leds in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
