M
matt25
Hi, im after some advice on an east/west split with a 4000tl please. I would assume it wise to turn on the optitrac feature due to the consistant shading issues an e/w system on a pitched roof would have? Has anyone ever compared yields with it on/off? All advice most welcome as this will be my first e/w installation! Many thanks in advance
East/West is a good option - especially if the home is occupied for most of the day.
I would recommend enabling optitrac. I'm still not sure exactly how it works but if you have shading issues then it's a winner.
Thanks. The east side will deinitly be shaded pm as will the west am. I had previously been told to enable during winter months and not for summer, although i think this may not be the best scenario for an e/w split though?
Ordiinary MPP trackers climb to the top of the nearest hill in the power output curve. IIRC OtpiTrac Global Peak checks there isn't a higher hill somewhere else. The downside is a slight loss of output while the tracker is checking for this. Shouldn't make any difference with a simple shading problem as in the sun moving round the sky, more useful where there are multiple/odd-shaped shadows passing over the array. More here OptiTrac Global Peak. SMA Solar Technology AG. [Grateful if someone could tell me how to post abbreviated links, maybe not possible with Quick Reply.]
There are 4 or 5 different approaches to MPPT algorithms - discussed here: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.119.6513&rep=rep1&type=pdf
Useful reference paper, thanks TedM.
(i) The results for the two methods with the best results (Perturb & Observe and Incremental Conductance) are very much the same, and so much better than Constant Voltage that no one would use that (and it requires prior knowledge of the panels).
(ii) none of the algorithms described are capable of dealing with more than one "hill" in the characteristic.
(iii) the cost of implementing the more complicated algorithms e.g. DSP or Fuzzy Logic in software is much lower now than when the paper was written so I expect in practice inverter manufacturers have their own proprietary algorithms which may use a combination of methods.
See also http://files.sma.de/dl/7418/GlobalPeak-UEN101210.pdf which has more details of OptiTrac. In particular it says the penalty for using it when there is no shading can be up to 0.2%. So this would seem to imply that for a simple E-W system where all the panels will go into shadow simultaneously you would be be slightly better off without it, presumably this is why you can turn it off.
Sma's response was "Probably best to enable it. Worst case scenario is you might lose 1-2% yield as the MPP trackers search for the best power curve. Without it enabled you could lose ten times more from shading"
The figure of 1 - 2 % is not consistent with their own data sheet, which says
"with this procedure, losses during searching are unavoidable. However, OptiTrac Global Peak is a search procedure specialized in keeping losses in times without shade at a maximum of 0.2 % when searching for a possible second power maximum. To keep these search losses even lower, it may be useful to adapt and reduce the frequency of searches (cycle time), individually for PV plants with slowly appearing shadows [2]."​
With an E+W design the shading due to time of day will affect all panels or none in each array and there will not be more than one peak on the power curve. So provided the E and W arrays each have their own MPP tracker the Optitrac Global Peak algorithm can't improve the yield. If it is really true that "it might lose 1 - 2%" then you would be better with it off. At least make the cycle time as long as possible if this is programmable.​
hmmmm must admit i did cringe when i looked at the weather report, not looking good. So if it was your house Powervan & Sharpener (this is mine in question!) would you enable or leave it off??
sma's response to sharpeners last post is below! what does changing the cycle time achieve? I’d already assumed that you’d be using both strings (A+B) of the SB4000TL to get the best out of the E/W scenario using both MPP trackers.
Cycle time can be changed from 6min to 30min using Sunny Explorer.
The following link will show you how shading can affect your daily yields. The video is pretty good at explanation.
http://www.sma.de/en/products/knowledge-base/optitrac-global-peak.html
Best advice is to monitor your systems’ performance (Sunny Explorer is free). If you encounter yield curves that suggest shading issues, then Optitrac is worth trying. You could then compare the yields with/without Optitrac and then make a decision.
It may be that Optitrac really helps at the transition stage between E -> W as the sun tracks across your panels.
AFAIK at the end of each "cycle" the Optitrac will check if there is another, better peak than the one it has been using. To do this it has to vary the current drawn from the panels from zero to maximum, measure the voltage at each step and calculate what is the best power output (power = voltage x current). While this is going on the array will by definition not be producing at its peak capability. So if the shading is only changing slowly then you want it to check relatively infrequently to minimise the lost power.
The SMA video is impressive but it illustrates severe shadowing over only part of an array caused by a dormer roof, this is quite a different scenario.
If it were my system I would turn it off. If you want it on I suggest setting the cycle time at 15-20 min, IMHO this would be a good compromise between lost power and following the sun round the sky (1/4 degree per minute). If the arrays are not perfectly flat there will be some irregularity of the illumination when the sun is due S but as it will be at glancing incidence to the panels at that point anyway you will not lose any significant power from that cause.
All this assumes that there is no other shading (from trees, pipes etc) and the E and W arrays are connected to separate MPP trackers, this will mean that as the sun moves from one to the other each array is continuously optimised in any case.
HTH
I have spoken to 4 guys at Sma on this and 2 of them say turn it on whilst another 2 say leave it off! I'll have to run my own tests i guess to see what happens, thanks again for your advice.
mmm 0.2% potential loss of earnings is still alot less than a hair transplant , flip a coin and live with it
Hi, after alternate week on week off recording throughout dec & january the winner is .............. global optitrac ON! by a magin of 7.1kWh (58.078 on, 50.942 off, courtesy of sunny explorer). Might do the same in the summer if the novelty hasnt worn off by then!!
I think it is too weather dependent for this to work over such a short period, unfortunately.
By comparison, my figures for alternate weeks starting on 5 December are: odd weeks total 79.876, even weeks 113.253kWh.
If I change the sampling period to be alternate weeks starting on 7 Dec, then the differences are even more extreme, 72.537 and 121.393 respectively. So my figures show more variability from week to week than yours even with no changes at all to the system!
Wow, very interesting and many thanks. I appreciate its all dependant on the weather and particular system but i had to base it on something. Im going to leave in on, as in my case it appears more than coincidence, hopefully this will prove the correct decision. After speaking to SMA again it was mentioned that they are hoping to implement a physical switch on their inverters to opperate "optitrac", apparently this is down to its continual success and making more customers aware of it.
Global optitrac, on or off for east/west split??
matt25,
matt25,
