Glowing cables | on ElectriciansForums
Discuss Glowing cables in the Australia area at ElectriciansForums.net
B
BlueToBits
I usually do commercial work these days, but I attended a domestic call out today. I don't do this very often but I happened to be passing on the way to another job. The customer was complaining of funny smell since last night coming from her consumer unit.
I entered the house to a haze of smoke and a stench of burning plastic.
So, after removing the cover of circa 1990 squareD board, I noticed a bright yellow glow coming from the under the MCB cable entry (these boards have a top busbar). Everything was far too hot to touch. A 2.5mm cable had burned almost right through, and was glowing like a filament and had clearly been cooking the consumer's unit for quite some time. I should have taken a photo but was too alamed to think about it at the time.
I've seen the aftermath of an electrical house fire several times, but this is the first time I have seen the beginnings of what would have almost certainly have become one.
Just thought I would share this.
It was 3.30pm and she had to collect her childern from school so I didn't get much time to investigate in detail. The circuit was a 32A ring with the offending cable spurred from the MCB and feeding another 32A MCB in a seperate enclosure. I suspect that this is a kitchen ring installed by someone who couldn't source a SquareD breaker so thought it would be OK to take a spur off.
I just isolated the circuit and am returning tomorrow morning with a new consumer unit.
Reply to Glowing cables in the Australia area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
