going out on own, need some advice | on ElectriciansForums
Discuss going out on own, need some advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
graham123
basically, been doing testing and inspection for a company for round 2 years now, and have been considering going out on my own doing it for myself, including some pat testing etc. Basicially i can never get a straight answer out of anyone as to what i need to go out on my own. ie insurance, napit, nic???. I have 2391, can i sign off my own sheets etc. Help would be greatly appriciated thanks
Well you would need insurance both Public Liability and Indemnity if your going to do T & I with PAT.
As for joining a scheme unless the work you get will insist that you be a member of a scheme then you don't need to be in any.
Unfortunately there are very few home owners requesting T&I work off their own volition, most domestic/commercial work is done through organisations such a mortgage or insurance companies who like the tester to be affiliated to a recognized scheme, mainly NICEIC for commercial/industrial
So in theroy i could do periodic inspections without being in a scheme?, and using test sheets which i can download from the net etc
Like Malcolm said, there are very few people requesting tests. The company you work for must have secured large contracts. Other than testing my own istallations I get little demand for periodics, maybe 2 a month. I visited over 35 estate and letting agents in Brighton offering a testing service and they all said they were not doing it as it is not law. Unfortunately until smeone of importance is hurt or insurance companies make it a requirement for cover landlords and home owners will not pay the money for the test. We are too expensive, "The Gas test was ony ÂŁ20". I wish you luck but would do it on the side until you can garuntee a steady supply of work
thanks for the advice, i was thinking about doing flyers/leaflets etc dropping round houses. Our company does get the occasional periodic on a domestic property froom people who are worried about their electrics lol. Most of the domestic testing is through letting agenicies etc.
i was thinking along the lines of maybe caravan parks testing of static homes?. Would i need to be part of a organisation if i was just doing periodics on domestic properites for the owner of the house?. I would only require my liability/idemitiy insurance?
If you decide to go alone doing T & I then you don't need to join a scheme, all you need is PI insurance.
However, when you're doing T & I then you'll often be "reporting" issues and necessary "fixes" and without membership of a PartP scheme then you'll be dealing LABC on a case by case basis which will most likely cost you more than scheme membership.
This is best bit of advice you can get................Do not do it!
The public will not pay for it and the domestic market is an absolute minefield.
Yes Graham if that work was extending a light in a kitchen or bathroom say then you MWC would have to be registered for Part P. All work in Part P locations that affect/extending a cables needs to be notified.
If you were extending that circuit same circuit but in a hallway then you don't need to notify it, even though the hall is on the same circuit as the kitchen as often is the case in a home, just part of the wonderful vagaries of the part p lunancy
Reply to going out on own, need some advice in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Persons who are not registered with a self-certification scheme - including DIYers - will need to notify or submit plans to a Building Control...
Niceic dont allow 3rd party QS sign offs, the main problem i found was building control notifications ,we actually paid the local authority the...
