gola exam
K
kmatthews
a capacitor of 100uf is connected in parallel with a 20ohm pure resistor. the group is connected to a 200v 50hz supply. calculate the power dissapated in the combination
can someone show me the formula for this
Will have a go at this but could be way wrong.
Impedance = C + R
Impedance (Z) = 120 ohms
Current (I) = V/Z
Current (I) = 200/120
Current (I) = 1.667
Power = VxI
Power = 200x1.667
Power = 333.4 W
Upvote 0
mmmh! interesting - i suspect this is a bit of a trick question. A pure capacitor will not disipate any power although it will produce a leading power factor. So you just ignore the capacitor and calculate the power.
You could use P=VxI and since you don't have a current value you could rearrange the formula by substituting in I=V/R to get P=VxV/R or P=V^2/R (V squared divided by R)
so (200x200)/20 = 2000W
(at least that is my take on it after a couple of beers!)
Upvote 0
Impedance = C + R
Current (I) = V/Z
Current (I) = 1.667
Power = VxI
Power = 200x1.667
Power = 333.4 W
I see what you are thinking, but the impedance would have to calculated from Xc which would be 31.8ohms (from 1/(2 pi f c) and then use pythagoras to get Z to equal 37.5 ohms
then I would equal 5.3 A and power would be 1066 watts . I don't think this is the way to go though, but hey its past my bedtime:D
K.Matthews can you remember any possible answers?
Anyone else got any ideas?
Upvote 0
Pushrod is pretty much there...
Here's how I did it & been doing a lot of Impedance revising...
First as Pushrod said get Xc
1/2PIfc=Xc
1/2xPIx50x100(to the minus 6)
=31.8
Then find Z (Impedance)
Z= Square Root of R sq + X sq
Z= Square Root of 20sq + 31.8 sq
Z= Square Root of 400 + 1011.24
Z= Square Root of 1411.24
Z= 37.56
Which is what Pushrod got...
P=V Squared/Z (Replacing R)
P= 200v Sq/37.56
P= 1064.96W
I hope that's on the a, b, c or d answer otherwise I'm knackered!
Hope this helps Mate. Got my 301 next Friday
Upvote 0
1/2PIfc=Xc
=31.8
Z= 37.56
P= 200v Sq/37.56
P= 1064.96W
Sorry to rock the boat but i'm still going with my first answer of 2000watts on the principle that i think watts are dissipated only in the resistive part of the circuit and that inductances and capacitances are"watt-less". The 2nd answer was just expanding on Sintra's thinking.
Now if the question was actually asking for apparent power (VAr) that would be different - you would then be adding currents by pythagorus before doing P =IxV.
I'm not betting my life on it mind!! :)
Upvote 0
kmatthews,
pushrod,
Electrical Courses
