Good lock off kit | on ElectriciansForums
Discuss Good lock off kit in the Electrical Tools and Products area at ElectriciansForums.net
Wiltshire
Can anyone recommend a good/ comprehensive lock off kit that will be compatible with the majority of domestic consumer units
I have a couple or the Kewtech kewlok type, a couple or padlocks and a full kit of fancy ones to show the NIC man.
I use the kewlok ones on a daily basis, the padlocks quite often for isolators and the big lockout kit comes out once a year as mentioned.
[ElectriciansForums.net] Good lock off kit
i use the type that inserts pins through the holes either side of the toggle. can't seem to find an illustration atm.
You mean a split pin?;)
no. the pin is embedded in plastic with the MBB switched off, the ends spring into those tiny holes either side of the toggle. the plastic bits have padlock holes in them for locking off. just found image of them what i have. obviously not as big as the enlarged image>
They can be undone without the code pretty easily.
Reply to Good lock off kit in the Electrical Tools and Products area at ElectriciansForums.net
Hey all, I am trying to set up a module that i can use to turn on headlights with lock and unlock so basically I have all things sorted out...
