Got an ex council house to rewire | on ElectriciansForums
Discuss Got an ex council house to rewire in the Lighting Forum area at ElectriciansForums.net
Hull in Yorkshire
Got an ex council house to rewire. Sockets are straight forward and will be doing it in T&E
But the lighting is done in singles 6241y. And I want to do the same. I have rolls of conduit wiring on the van, but not sure if this is suitable for slotting down plasterboard soothing walls or popping through the existing holes in the joists.
Sould I bite the bullet and use the pvc/pvc 6241y or use t&e
You don't seem vey experienced in domestic work. Are you a scheme member?
Agree with ANDY78
He does mention conduit wiring.
Yes, when I re-read the original post, it is not clear if he wants to use unsheathed conduit wiring, or this sheathed 6241Y. I was assuming the OP knows the difference between the two, and that unsheathed cables must be contained.
Personally I can't see why you'd not just use T&E, unless of course you happened to have a van load of something else that you wanted to use up!
6241y? Meaning singles-and-earth?
Are you sure it needs rewired? Should still be in ok condition.
The main problem with that is, even though it's in good nick, positioning and number of points required. We all know the number of sockets, especially, that are required these days compared to days of old. Additions to a domestic conduit system can be a real ball ache, whichever method you're going to use.
Reply to Got an ex council house to rewire in the Lighting Forum area at ElectriciansForums.net
