Darkwood
Just wired 85m x 4core 16mm swa on tray arkward run took all day getting it in, anyway came to terminate it and found several steel wire strands missing from within the swa -
The cable does not give 360 mechanical protection and I now have to work out if my earthing is adequate or whether I've to waste my time adding an earth, the cable is Prysmian so heads up out there check your cable isn't a bad batch or even fake.... I mean, more than one key area has cocked up in the manufacturing of this from the machine not shutting down when it ran out of wire to quality control not catching the issue.
(H6944X 16.0mm XLPE/SWA/PVC Cable)
