Green Oily Residue in Sockets & Switches | on ElectriciansForums
Discuss Green Oily Residue in Sockets & Switches in the UK Electrical Forum area at ElectriciansForums.net
V
Vitesse
I got a call today to go to a house where the owner had a problem with a light in the bedroom that would intermittently flicker on and off. Especially when first switched on, it would come on dimly when first switched on and then go out, then light up normally. It had one of these touch sensitive dimmer switches.
She she said that sometimes when her daughter and mates were in the room and jumping about it would sometimes flicker on and off. It was a single ceiling rose and bulb, so got up there and had a look for anything obvious, nothing standing out. Taking the bulb out would have the same effect as before.
So I checked the voltage and it was about 232v. Checked the voltage at the socket for a comparison and it was ok about 242v.
I had a look at the dimmer switch and the first thing I noticed was this green oily slime on the end of the wires when I unscrewed it. So I mentioned it to the owner and she said it was all over the sockets and switches. She showed me a socket at the top of the stairs and one in the kitchen and both had evidence of this green staining on the bottom of them where it had been seeping out. She said all the neighbours houses had it as well. Anyway I changed the switch for a one gang one way switch and it cured the problem, checked the voltage at the ceiling rose and it was back up to 240v.
The house was built sometime in the 70's, still has the original black and red t&e. Obviously the green is from the copper and I assuming it is some sort of reaction with the insulation when it heats up that is producing the oily substance?
Has anyone come across this before? I have to go back next week and do another little job so I intend to do an IR test just to see what condition the wiring is in.
Cheers guys. I must have been really lucky not to have come across it before considering how long I have been a spark.
I should have known JW on YouTube would know about it.
I don't think it will go down well if I told them the only solution to prevent green goo is to rewire the house and I have to wear protective gear to do it!!!!!! Could be a nice little money spinner though to rewire the whole development!!!!
I will just tell them to take care when touching it and make sure the wash their hands afterwards.
I think a rewire is only required, if the integrity of the cable has been affected, i.e. insulation resistance and if the slime is bad enough to affect decoration or coming into contact with persons. There are quite a few properties suffer with this slime, but carry on with no problems. Personally, if I had a property so affected, I would rewire, but it's not necessary in all cases.
I have come across this green slime lots of times. I done a CU change on a bungalow that had lots of this green slime. When I did a few tests prior to changing the CU, the IR tests were good. +200 M ohms on most circuits
NO! tell them it's highly toxic and their hair will fall out. must be rewired immediately at a cost of ÂŁ6000 + ÂŁ2000 toxic waste disposal. where's your entreprenurism gone ?
Remember the first time I had this was a board change and had no idea what it was as only one radial was affected. Best bit was I used to put my driver in my mouth whilst stripping etc, stopped instantly after that cos it burns like f@@k. Did manage to con them into a 15k Rewire on that basis tho which was nice
Was it Buckingham Palace?
Seen it on a job and gave the client all the info on it. I said that I recommend a rewire but it was their decision at the end of the day. Wasn't the worst case and they decided not to rewire. At the end of they day all we can do is recommend, the final decision is up to the client.
Reply to Green Oily Residue in Sockets & Switches in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
