Greenhouse supply | on ElectriciansForums
Discuss Greenhouse supply in the Australia area at ElectriciansForums.net
spikeyblueeyes
Need some help have a customer who wants a double socket in a greenhouse to use a heater on there is a supply on a garage just two meters away which is fed from the house and is rcd protected what can I use, do thanks thecable from the house is buried about 450 mm in PVC conduit can't find any info in regs thanks
i just threw that in for opinions. personally, i would class it as structural metalwork and bond it. like to see others' thoughts.
Reply to Greenhouse supply in the Australia area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
Hence the former name for TNC-S, PME. Protective Multiple Earth.
