Hello and thank you to all who helped at post ID http://www.electriciansforums.co.uk...241-grey-haired-sawdust-maker-needs-hand.html
I am replacing the Mains In and Supply Out isolator switch and would welcome knowing what terminals to use.
Setup is 240v 1ph running 2.2kw (3 seperate) motors which will supplied from distribution point using industrial 3 pin 15a connectors.
Accordingly I am looking for advice on supply in and single supply out connection.
I attach 2 x pics of the isolator switch.
