Grid boxes for kitchen spurs | on ElectriciansForums
Discuss Grid boxes for kitchen spurs in the Australia area at ElectriciansForums.net
Gordon
Surrey
Can anyone advise best practice for installing a grid system for kitchen appliances, i usually install separate fused spurs for each appliance but have been asked to install a grid on my next re-wire. do you feed it with a 32A radial or install it on the ring main. Any tips or advice gratefully received.
depending on how many appliances and how much power they will use you may need a dedicated supply, if its only a few low power items then use the kitchen ring. Make sure you fit an extra deep backbox.
Reply to Grid boxes for kitchen spurs in the Australia area at ElectriciansForums.net
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
