Discharged
Hi
I'm looking to install a switch into a box like this one:
... and so will require a lead going in and one coming out. I need to find a way to hold the leads in a safe and secure manner, but don't want to/can't use 20mm glands - they'd look ugly in this, and are just wrong I think. But I'm pretty sure that I have seen something like grommets which you would slide over the top of the cable and located in a hole that was cut into the box. I imagine that the box will be split horizontally, and the hole for each cable will be centred on that split line of the casing.
Can you see what I'm trying to ask about here? Where can I get a grommet that could hold a 1.5mm twin + earth, and sit on one half of the casing, and then put the other half of the casing on top and screw it down?
I think I need to know the name of the item, so that's where I'm a bit stuck. I can find some grommet-like things on RS Online, but I'm not convinced they're what I need. I think I want something that is probably no bigger than perhaps 5mm long?
Anyone help, please?
