Grounding PV | on ElectriciansForums
Discuss Grounding PV in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
wv
Besides the NEC code, will someone please explain in detail why the DC side of a solar array need to be grounded with the AC inverted side of the electrical system. I have two 2400 watt arrays pole mounted that supply a 48v dual xantrex 4024 inverted electrical system. I am being told that I must ground the two arrays directly to the AC side of the system. When I originally installed it I placed ground rod adjacent to the structure housing the electrical equipment which served the system well until I later connected the PV system AC output to a newly constructed home. I grounded the inverters only to the home system and left the disconnect box and the rest of the DC system grounded to the independent of the house system.
I have been informed that I must disconnect the independent dc ground and connect all grounding to a single earthen ground. I do not want however, any possible lighting strike on my panel array to go any further than that. One would think that the massive 6 galvanized 12 foot poles buried 4 foot in ground would suffice. I have surge arrestors in place at the combiner boxes on the array poles. Yet I say again all the DC grounds But I did ground the DC electrical components to a central copper earthen ground at the structure housing all the electronics.
Will someone please explain the benefit of combining the two?
Reply to Grounding PV in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
To start with the power companies don’t supply the equipment ground, that’s where the ground rods come into play. # 6 wire is required for the...
Sorry for the late response but by the NEC code book requires one ground rod near the panel and another ground rod at least 6 feet or more using #...
