Grundfos Magna1 twin pump control | on ElectriciansForums
Discuss Grundfos Magna1 twin pump control in the Central Heating Systems area at ElectriciansForums.net
London
Hi to all,
I have got dual pump set Grandfos Magna1 installed. Those pumps can be constantly running when paired wirelessly.
However, I would like to be able switching them on and off separately, for example 3 hours pump1 is running then pump2 for another 3 hours.
To achieve that I assume integrated relay terminals must be used. Do you know any single device that can be used to control those relays in some intervals?
Thanks,
Rafal
Why 3hrs changeover,?
On twin pumps its usual to set them to change over either every 24hrs or each time they start up.
On Magna twins you can do 24hr changeover without any external control, apps or having to use Grundfos GO.
Do anybody can help with above please?
In my scenario, I have dual pump set which (if I understand correctly) to operate separately each of them required permanent power so both can "remember " settings on "display" and small link wire has to be removed. Than those terminals can be used to start/stop function.
Also, at the beginning both pumps must be unpaired.
In my case, one dual head pumps are used for heating so needs to be switched on only when call for heat. Another dual head pumps are for hot water and same, switch on when call for hot water.
Reply to Grundfos Magna1 twin pump control in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
