I
irishman
Hi
I have a small issue if you can help.
Kitchen with 8 spotlights all using gu10 bulbs. First 1 blew, then a few days later 2 more followed.
I replaced them with new, still not working, so swopped some working 'old' bulbs for new and the same 3 wouldn't work.
Ive checked the wiring and no problem there.
any ideas?
assume these are halogens and not LEDs?
All halogens, wiring looks fine. Not cheap, supermarket brand bulbs although gu10 are not pricey. insulation looks ok, goid gap above the bulb so it shouldnt be overheating, plus when I put the bulbs elsewhere they worked fine
best place for halogen bulbs is buried in the garden. if you are quick enough in the spring, you might be able to harvest some LEDs.
all halogens, wiring looks fine. Not cheap, supermarket brand bulbs although gu10 are not pricey. Insulation looks ok, goid gap above the bulb so it shouldnt be overheating, plus when i put the bulbs elsewhere they worked fine
hum!!!!!
Gu10 bulbs
DIY Electrical Advice
Thread Tags
Tags Tags
bulbs gu10
irishman,
brucelee,
