Gu10 flicker | on ElectriciansForums
Discuss Gu10 flicker in the UK Electrical Forum area at ElectriciansForums.net
O
optician
In need of a little help please.
I have a customer with 10 gu10 12v 20w
down-lights on a push on/off dimmer.
On full brightness all the lights pulse/flicker regularly every 1-2 seconds.
dim them slightly and the pulse stops.
The dimmer is a 230v 50 hz
40w/va-220w/180va.
Anyone able to help?
Many Thanks Dave G.
Reply to Gu10 flicker in the UK Electrical Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
