gu10 mains lamp blowing | on ElectriciansForums
Discuss gu10 mains lamp blowing in the Australia area at ElectriciansForums.net
J
james king
hi all i have changed 6x gu10 downlights in a kithchen as the down lights befor kept blowing there were LV.
what may cause the lamps to blow regualy eg only 3-4 hours of being on? all suggestions would be grat
both the LV
and the GU10 lamp blow after about 4 hours four of the six go. there is clear ventilation no insulation over them. the new down lights are fire rated. all test seems ok >99 IR and 0.89 R1+R2
lamps genarally have a tolerance,sounds just like poor quality lamps,halogens are so hit and miss,some last years,my bathroom ones have lasted 8 years(hope i dont tempt fate here)no failures,others like my kitchen go regular,although they might look pretty,downlights can be a real pain,the next client to ask me to fit a load im gonna recommend led spots as the saving over time pays.
so i think what i shell do is do a continutity test between L-N and N-E so test for loose connection? what do u think. i fitted 6x low enegry lapms when i fitted them and they did not blow!! but she didnt like the light and wanted GU10 buls insted since then 4 have gone
Reply to gu10 mains lamp blowing in the Australia area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
C
Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks, Would like to cast the net far and wide to try and get some resolution...
ComfortablyNumb
C
