Guess the fault | on ElectriciansForums
Discuss Guess the fault in the Australia area at ElectriciansForums.net
P
p11jor
Had a call out late last night, everytime the shower comes in it's blows the whole house.
The set up of the board is duel rcd. 2 mcb either side.
Cooker/shower on left
Lights/sockets on right
So the power to the shower switch is fine, again this can function fine and send power to the shower, bit as soon as the shower is pressed is wipes both rcds straight out after 2seconds.
I did a insulation resistance test, was getting 0.25megohms.
Removed tge switch and was getting 459megohms. So thought new switch, put new switch on and still wiping the whole board out, but obviously were not getting a dead short as the power to the shower is fine untill pressed.
Quite interesting this one. But such a obvious one which I will always look out for on my future PIRs
If it's taking out both RCD's then there cannot be any discrimination between them, ie. there is a common point between them. Are the circuits correctly fitted to correct sides of board, more to the point the nuetrals as this would not trip until power runs through the appliance. i know this seems like a daft suggestion but to take out both RCD's there has to be some kind of connection between them.... And the number of customers that try to do their own work without the faintest idea is gobsmacking, always remember they may have been in the board before you..!!
Agree. Shower neutral connected to wrong neutral bar in CU.
It's was guys, the bus bar there was only a 6mm separation between them and as soon as my mate pressed the shower the Lecky jumped from one bus bar to another, And wiped the whole board out.
Snipped it back....jobs a gooden!
Don't take that 6mm as a set in stone measurement (as you know diy and poor sparks put them in and they angle slightly, again I taken a measurement from the bottom of the bus bar so it may of been 2mm at the top) I didn't care it was late, dark I found the fault so was made up to fix it and go home without measureing the degree of angle it was on......but whatever it was they were not touching and with it being dark I could see tge jump of 230/240 to the next bar.
I don't kno why all of a sudden this has happened but he had been away and he bought a cooker that was fitted when he was away, there is a 6mm supply for this but the new cooker was just gas range with a ignition, so apparently they swapped the cooker plate behind the over for a fuse spare and ut a 3amp fuse and wired the 1mm flex in the fuse spare.....don't see any reason for them to be in the board though???
Also as tge house is a 2 up 2 down there is only 1 circuit for sockets and one circuit for lights, 12 sockets, 6 lights, I didn't see tge need in swapping these over, as 1 I didn't install it and two it was dark, late, and not my install.
Reply to Guess the fault in the Australia area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
