Guidance Please | on ElectriciansForums
Discuss Guidance Please in the UK Electrical Forum area at ElectriciansForums.net
K
Kirvy
Hi there, I'm new to this forum. I'm going to install a double socket and a light in a garden shed. My plan is to run a switched fused spur off the kitchen ring as a spur to the shed, where I'll put a double pole switch and then the socket and light. I'm using some steel armoured cable underground to run from the fused spur to the double pole switch. I believe this will only require a MWC. Would that be correct? As such its not notifiable, is it? I have the appropriate qualifications (2391, 17th ed etc) but I'm not registered yet (took all the courses and then got a job that didn't require me to get registered) and I am comfortable with the testing required, but as it is a while (about a year ago) that I qualified, the details of certification etc are a bit rusty and I just want to be sure I'm doing it right. Your help and advice would be :38:gratefully received.
Installing a spur from a ring final circuit would not be notifiable work in England, but would be in Wales, is not applicable in Scotland, not sure about Northern Ireland.
In each case a minor electrical installation works certificate would cover this.
The technique you describe does not sound good but would meet the regulatory requirements.
you need to fuse down with a 5A FCU for the light/s. and how are you going to gland the swa?
2.
Even though it is supplying a garden building ? I didn't know that.
Just read what is notifiable work in the approved document and it now looks pretty much like it is only in rooms containing a bath or shower etc. If this is right it is bloody expensive to be a member of a scam scheme just to notify work in these areas isn't it ??????
Yes.
Doctors pay less to be registered each year. We are well and truly reamed.
In fact I have just read that too and there isn't much anymore and loads of get outs.
Reply to Guidance Please in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Ouch. Danger notice to customer in my book.
