K
Kirvy
Hi there, I'm new to this forum. I'm going to install a double socket and a light in a garden shed. My plan is to run a switched fused spur off the kitchen ring as a spur to the shed, where I'll put a double pole switch and then the socket and light. I'm using some steel armoured cable underground to run from the fused spur to the double pole switch. I believe this will only require a MWC. Would that be correct? As such its not notifiable, is it? I have the appropriate qualifications (2391, 17th ed etc) but I'm not registered yet (took all the courses and then got a job that didn't require me to get registered) and I am comfortable with the testing required, but as it is a while (about a year ago) that I qualified, the details of certification etc are a bit rusty and I just want to be sure I'm doing it right. Your help and advice would be :38:gratefully received.
