Hafele LED lighting | on ElectriciansForums
Discuss Hafele LED lighting in the Electrical Tools and Products area at ElectriciansForums.net
They do seem a bit steep ! I have fitted the Halers H2 downlights in a number properties and am quite impressed with the light quality and output from them. You can now pick up the non dimmable version of these for less than ÂŁ30 + Vat, which I think is quite reasonable.
Have to say, they arent a patch on the hafele looks wise. I was a bit dubious having a 103 mm fitting, but when they were all in place, have to say they looked great. How do you wire the Halers mate? like normal DLs, these I found, after first fix , and new ceiling fitted are via a driver, one driver 6 fittings, was VERY lucky I could pull the wiring round via my twin and earth. FUMING when I turned up for second fix.
Reply to Hafele LED lighting in the Electrical Tools and Products area at ElectriciansForums.net
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
