Hafele Loox 24v LED Kitchen Lighting | on ElectriciansForums
Discuss Hafele Loox 24v LED Kitchen Lighting in the UK Electrical Forum area at ElectriciansForums.net
West Yorkshire
Afternoon All!
I have a kitchen installed with Hafele Loox LED system. There is two 24v 15w drivers, one running two Loox 3015 flexible lighting strips. The other driver is running a single Loox 3015 LED strip. Links below.
LED Flexible Strip Light 24 V, Length 5000 mm, Rated IP20, Loox LED 3015 - Häfele U.K. Shop - https://www.hafele.co.uk/en/product/led-flexible-strip-light-24-v-length-5000-mm-rated-ip20-loox-led-3015/000000450000630400040023/#SearchParameter=&@QueryTerm=24+v+loox+3015&@P.FF.followSearch=9728&PageNumber=1&OriginalPageSize=12&Position=4&OrigPos=6&ProductListSize=36&PDP=true
Driver number 833.77.900 15w
My question is the Hafele system only seems to sell the lighting strip I need in 5m lengths well in excess of ÂŁ100. Do I have to use the Hafele loox or are there far cheaper options I can still just plug into the drivers I currently have? I'm just looking to add around a 1m and then a 1.5m sections on top of the cabinets, the drivers are all sat on top ready to just plug the strips straight in just dot know what other options I have if any??
Thanks for your help.
Jon
Some, if not most retailers of LED strip will sell via the cut length of the strip, e.g. 100mm. When adding to your existing drivers, you'll have to work out, what the current load is, and what the additional load will be, when adding any new strip.
Reply to Hafele Loox 24v LED Kitchen Lighting in the UK Electrical Forum area at ElectriciansForums.net
Thank you for your reply. I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing...
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
