Hager DB | on ElectriciansForums
Discuss Hager DB in the UK Electrical Forum area at ElectriciansForums.net
leep82
Stoke on Trent
Can somebody help me out and suggest what other makes of MCB's will fit a Hager distribution board. Thanks.
I have seen people jamming different types of breakers ie wylex in a volex board because they could not be bothered to get a branded one that was designed for that board,the busbar sizes can vary between manufacturers,and as said just use a hager,not only do you make sure that no warranty would be invalidated but also installation practise could never be questioned as to fitting the incorrect part and the implications that could arise from this.
Seen wylex in a hager DB yesterday. But as said why. Can understand as a work round late at night or a Sunday or something but always go back and change it mainly because it looks pants. If you have enough time to research it you have enough time to get or order correct MCB
I take your point but Wylex, Crabtree and Volex are exactly the same design, made to the same specs in the same electrium factories so, excepting the sticker on the front, they are exactly the same.
Sometimes its not about the functionality of something, but making it look like a proper professional job with a clean finish instead. Not just throwing in any old breaker as long as it fits.
TLC.co.uk sell Hager at a good price with ndd, no excuses not to get hold of any really.
I was merely asking which other types would fit a Hager board, people seem to have jumped to the conclusion that I will be fitting somthing different. Just trying to gain a little knowledge for future reference that's all
Given what you asked, what other sort of 'conclusion' did you expect people to jump to?
That aside, it costs very little to keep a decent selection of most makes of MCBs on hand, so there's no real excuse for not using the same make MCB and board. And as someone has already said, sometimes its as much about doing a professional job and doing it well as anything else.
There's nothing rougher looking than CU with all varying makes of MCB, apart from Janet Street Porter that is :puke:
What future reference is that?
As has been said they are one of the more common ones available from most wholesalers, cant see why you would fit another type in this instance.
maybe a scenario as has already been mentioned arises and its to late to get the specific make of MCB you require for the board. If it meant getting a supply back on as a stopgap and I only had such and such make MCB on my van I would fit it until I could get back to fit the correct one. I only posted as im relatively new to the board and not posted much. It was a topic that was being discussed at work today and I know different makes will fit different boards so thought I'd raise a topic about it. Never mind
Since Nov 2011 - that 's not new.
Reply to Hager DB in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
