Hager invicta 3 a board | on ElectriciansForums
Discuss Hager invicta 3 a board in the Electrical Tools and Products area at ElectriciansForums.net
They start from around ÂŁ100 for a 4 way and about ÂŁ250ish for the 16 way.
Plus you will need to buy all the switchgear for it.
RCBO's for these are different for the normal cu and command a premium at about ÂŁ45 each.
Not cheap!
I know it's not cheap but nor is the job so this is what I will be fitting. Will look great tho :). Do you know what is different bar price on the rcbo's
Reply to Hager invicta 3 a board in the Electrical Tools and Products area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
