Hair Salon Backwash shower unit. | on ElectriciansForums
Discuss Hair Salon Backwash shower unit. in the Australia area at ElectriciansForums.net
W
weston29
Evening Chaps,
Been asked to look at a job for a customer in a hair salon. Wants a back wash unit fitting in the rear of the shop, cable run is easy enough and the consumer unit would accomodate it with a spare way being facilitated (RCD protected unit). Never done one before and was wondering if anyone knows if these units are purpose built or is it fit a standard domestic shower??? With it being in a salon, I can see it getting hammered and shortning the life span of the unit itself and also the cable over time. Worried about voiding the warranty of a domestic shower being used in a comercial premises as well?? Any ideas??:confused5::confused5::confused5:
I used to use a commercial salon unit called allfow they had a good spares/service backup. Dont know if they still trade. Triton do a pro model as well three wires in, supplementary bonding advice would best come from a UK based member.
When i used to work for a company years ago i was sent several times to a Hair salon to change 8.5 kw domestic type shower unit that they used for hair washing. If i remember correctly they used Wickes own which were Triton ones rebranded. They always kept one or two spare units and took them back under warranty as the design had been the same for ages. If you're doing the plumbing then make sure it has a ballafix valve with a flexible hose on to aid changing units in the future. Bit naughty using the warranty like this but a unit would last 18 months plus.
I know this is an old thread.. After your opinions
Hair salon with a row of back wash units, the chairs are "massage chairs" with individual remote controls for each chair.. Each chair has a standard double socket on a pattress on the floor under the base of the back wash sink..
If I shine my torch down the gaps in the chair I can just see the socket.. But there is no access to this socket..
My observations were..
No access to socket outlets
No local isolation for each chair unit
No RCD for socket outlets
It looks like 4 x outlets 1 under each unit on a 32a MCB
[ElectriciansForums.net] Hair Salon Backwash shower unit.
Your thoughts on coding.. C2's?
You know how the yanks love irony,for sure someone HAS to do their equivalent of an EICR on that baby,a C what? covers that scenario...
What about the fact I can't inspect or test the circuit. Can't access the socket outlets, you can't even unplug the plug top, even if you wanted to. Can't get R1+R2 (unless calculated), IR would have to be LN to earth.. Being as you can't disconnect the load
Reply to Hair Salon Backwash shower unit. in the Australia area at ElectriciansForums.net
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
