Morning Chaps/Chapesses,
I need to install some LED downlights in a kitchen ceiling with a standard 6"/150mm joist, but it's going to have wet underfloor heating for the rooms above clipped to it as well (as in, the floor boards, clearly).
I normally use the little Halers EVOLED units which I think are great, and the manufacturers booklet just says they need a minimum of 50mm vent space above, but makes no mention of extraneous heat sources.
Also, being so close to a plastic waterpipe which lets face it could easily be pierced from above through the board, do I have to consider some additional protection - and if so, then what?!
Anyone had this before? Suggestions welcome.
