I am having problems with a home built magnetic water level sensor using a reed switch, whereby the reed keeps sticking or failing to operate and I was thinking of using a hall effect sensor and a power transistor but I am unsure of the characteristics of hall effect sensors.
Are they susceptible to failure on exposure to high magnetic fields and are they sensitive to the angle of incidence of the magnetic field.
For clarification this is for a solar powered rain water recycling system running a 24W 12V water pump, I am trying to keep the circuit as simple as possible: magnet floating in water as water falls it activates the reed switch and switches on pump until water level lifts the magnet away from the switch. let me know if you need more information.
Cheers
Cheers
