Halogen potlights no longer working | on ElectriciansForums
Discuss Halogen potlights no longer working in the UK Electrical Forum area at ElectriciansForums.net
Andy S
Milton, ON
Hi everyone,
I have 4 x MR16 (halogen) potlights running off of a switch.
Model: IT2000M from Contract Lighting Contraste - IT2000M - Remodel - https://www.contrastlighting.com/Housing/IT2000M?lang=en
The other day, there was a humming which I believe was coming from the electrical panel and then the pots stopped working.
I moved some bulbs around but none of the pots fired back up.
I have tested the light switch and it appears to have power and the breaker, which services other switches, appears to be fine.
When I check for power at the pots, there appears to be no power.
If one of the transformers were to blow, could this knock out power for all 4 pots?
Recommendations for next steps?
Appreciate any help you can provide.
Andrew
[ElectriciansForums.net] Halogen potlights no longer working
Hi everyone,
Andrew
You could still have power to your switch but it’s probably going bad and breaking down. As far as the humming in your panel breakers also go bad especially with a consistent heavy load like your pot lights. When there bud how about sharing LOL
Reply to Halogen potlights no longer working in the UK Electrical Forum area at ElectriciansForums.net
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
