Discuss Halogen replacement bulb suggestion in the Lighting Forum area at ElectriciansForums.net
here, and loads of others.
5W E14 E27 B22 LED Golf Light Bulbs Dimmable SES ES BC Globe Lamp Cool/Warm VGLF | eBay
Dimmable : Dimmable or not, choose from the above options. If you use a halogen switch. It may cause the LED lights to flicker. Cap Type : BC B22-Bayonet Cap / ES E27-Edison Screw / SES E14-Small Edison Screw.www.ebay.co.uk
you'd also need a LED compatible dimmer. your existing dimmer switch will probably not dim correctly and also cause flicker.
Reply to Halogen replacement bulb suggestion in the Lighting Forum area at ElectriciansForums.net
