hand dryer distance from sink | on ElectriciansForums
Discuss hand dryer distance from sink in the Electrical Appliances Forum area at ElectriciansForums.net
davidrcasey
good afternoon, does anyone know if there is a minimum distance required between a hand dryer and the sink ?
thanks in advance
Back to the OP and the measurement is 300mm which I think is too close so if the kitchen is big enough make it 600mm
The book I named in post #2 is worth buying
Best to mount the dryer directly over the sink. That way you can wash and dry your hands at the same time. Saves a lot of time. Or takes ages. I forget which....
Reply to hand dryer distance from sink in the Electrical Appliances Forum area at ElectriciansForums.net
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
