Handy tools | on ElectriciansForums
Discuss Handy tools in the Electrical Tools and Products area at ElectriciansForums.net
W
Wayne Gollop
What tools do you have that you find handy. I'm looking to get some new tools and was wondering what you guys find useful. Other than the obvious!
Hmm, the "obvious" varies a lot...
Here's my main kit....
- Wera 7 piece VDE screwdriver set
- Random other VDE drivers as backup
- NWS side cutters
- NWS croppers
- Draper rod set (yep, I was being cheap! Much better are available!)
- Ratchet crimper (mine is cheap, but has done the job for years!)
- Bosch 18V combi drill/driver
- Mini claw hammer
- Mini adjustable spanner
- string
- Big box of bits... (could be anything in there really! Usually mine contains Wagos, crimps, ties, clips, a condom just in case (keep it away from the nails and screws), choc blocks, tape etc...)
- Bosch 240v 250w multi tool, Recent purchase but finding loads of uses for it.
- 3.5 tap (as essex said).
- 2xAA Maglite (LED).
- RoughNeck Utility bar (great for board lifting).
- Dewalt Impact driver 18v.
A little 3.5mm tap to clean out lugs on back boxes.A lifesaver on many occasions
They sure are!!
- NWS side cutters
- NWS croppers
- Mini claw hammer
- string
Why a mini claw hammer??
Box of bits!! I had to buy a 4 tier organiser. But it was the best thing I've done.
Im looking for the unusual tool that gets me out of a sticky situation or makes the job quicker and/or easier.
rotary stripper to take the sheath off flex without piercing the conductor insulation. got mine from cpc farnell.
apart from the obvious gash.............a pair of clear bolle wrap around safety specs ( cool ones )....had a nasty incident with spring loaded consumer unit screws once....always wear em when on't tools now lad..............and angry birds on your android fone...for the quiet times........head torch ...life safer....at least one in every jacket...tool belt......tool box....glove compartment.....I could go on......
oh and a tidy lil earth leakage clamp meter.....apart from its obvious uses....its hey misses.....watch this lil jasper go up when you try your tumble dryer......faulty fridge...etc.....you trusting person you
Clamp meter! Which one do you recommend? At good price!
Head torch is a must - you're never in your own shadow or have a light shining in your eyes, and have both hands free.
Another good one of mine is a tack-lifter. I didn't buy it for and never use it for lifting tacks, but the cranked end is perfect to nibble away the insulating foam behind thermaboard when fitting fast-fix boxes.
Magnet on a bit of string is a life-saver too.
Reply to Handy tools in the Electrical Tools and Products area at ElectriciansForums.net
I have tried pretty much every tool bag ,box, bucket ,case, caddy, tote organiser that you can imagine. and I have gone full circle and just gone...
Aye .... one can never have enough screwdrivers .... or pliers, crimping tools, stripping tools and cutters .... One of the best tools I've...
