First time poster here seeking a little advice/confirmation
I have spurred off to a fused switch and from there running two 2.5mm cables to the alcoves either side of a fireplace where shelving have been built into.
The shelving either side of the fireplace has LED strips fitted which are running from a 12V 60W multi port driver that comes with a standard UK mains plug. Now being as these are to be powered from that fused switch, I’m assuming that I can simply cut of the mains plug from each of those multi-port drivers and hardwire each of them directly to those 2.5mm cables using a 13A terminal line connector such as this:
B&Q White 13A Terminal line connector | DIY at B&Q - https://www.diy.com/departments/b-q-white-13a-terminal-line-connector/178107_BQ.prd?storeId=1199&&&gclid=EAIaIQobChMI6J-636m_ggMVyNbtCh3dxA6XEAQYAiABEgJQWfD_BwE&gclsrc=aw.ds
Any reason why this can’t/shouldn’t be done?
Any input and advice would be greatly appreciated. Many thanks in advance!
