Harmonisation of colours, PME & don't snip out cores! | on ElectriciansForums
Discuss Harmonisation of colours, PME & don't snip out cores! in the UK Electrical Forum area at ElectriciansForums.net
Top Cat
Gloucester
Changed a C/U today, when i took cover off found live = blue, neutral = red, with cable ties marked L & N in correct position. This was the same at meter so it must have been the meter guy! The meter had a test date of 2006, outside meter box probably fitted about same time. PME must have been done at same time. Notice the connector on earth, 16mm from meter box, then 4mm! Also notice the snipped out cores on 25mm tails.
  • [ElectriciansForums.net] Harmonisation of colours, PME & don't snip out cores!
An inch away from reverse polarity IMO , which is a sackable offence for the meter fitters.
Usually they dont need to touch the CU when changing the meter , just reconnect tails as is.
But rough yeah.
Not a link mate, just my favourite song to play. Look it up on youtube...you might even come across me on there...
Fair play that was mesmerizing, almost went into a trance watching! The first person to come up playing was Jim Greeninger. I would love to see some of your work (you may be Jim!). If you don't want to put it on the forum could yo PM me.
Reply to Harmonisation of colours, PME & don't snip out cores! in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
