has any one used one of these before?? | on ElectriciansForums
Discuss has any one used one of these before?? in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Horstmann Centaurstat 7
Im thinking about fitting it for a customer that has trouble working there existing programable stat.
Can some one tell me if there any good
thanks
They are ok, just like most programmable stats
Some of the Honeywell ones are even more complicated
What is you client after ? (i find the older the generation the simpler is needed as they do not like the newer tech)
They are easy enough to program, just depends on the client
If you have a main programmer else where for heating and hot water on a system boiler a dial or digital roomstat is good
Combi boiler with out intergrated timer then a programmable stat is the only option to go for, stay away from the Honeywell and it should be fine for the less tech client
Reply to has any one used one of these before?? in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Which begs the question, where does the second brown wire come from?
