H
hutch6447
Good info, also as I am just used to surface laying this whole chase cutting is a bit of a new experience, now the chases has capping in it and has to be deep enough to accommodate it, the metal back boxes are 35mm deep so sometimes do you have to chase into the brickwork itself as sometimes you must o deeper than render? Take it this is the reason for vertically 1/3 wall thickness horizontally 1/6 no deeper than.
To get this right your installing new cables into a brick wall.
Would it be easier to dry line the wall, that would give you studs to mount your wires to - might be more costly in materials but possibly cheaper with your labor costs - of course thinking its inside a building in the warm and dry - might be something worth thinking about.
Your deduction in labor costs might be cheaper for the customer than the extra materials as you may only have to dry line 2 or 3 walls, all depends on how many walls have sockets and wires behind them
generally, cables and capping just need you to chase out plaster depth. for back boxes , as you say, 25 - 35mm deep needs chasing the brickwork. best way i've found is to stitch drill the brick to the size of the box, then chip out with chisel.
sometimes though you will find that brickwork lies just beneath the plaster surface......so then you need to go into the brickwork.....but if i can avoid it i will..as i dont fancy spending ages banging out hard brick.....
What you really need is a masonry circular saw or grinder. Cut your lines either side of the boxing and chisel it out - its easier than doing it all my hand
Yes just because i have been a sparky last 12 years in the army anything we have installed as bee surface mounted so all this is fairly new to me!
I have tried most methods for digging out brickwork for boxes and have settled on a core drill (4") to set the depth and then a SDS chisel, if you are lucky the whole core comes out in one or two chunks leaving you the corners to tidy with the SDS chisel. A box chaser works on soft brick and blockwork, even if you only use the drill part to get rid of most of the hole and a chisel for the corners.
My left hand has now refused to hold a chisel when my right hand has a hammer in it. I have finally worked out that I get the best results if I hit the metal bit on the end of the chisel rather than my hand but I still hit my hand out of habit. So now I am just aiming for white finger with the SDS hammer :-)
Second vote here or scutch chisel being weapon of choice. When i have a lot of brick to chase out I sometimes switch to my dewalt 110v with rotary stop and chisel attatchment. Good for chases, but i aways do boxes by hand to keep them neat for fixing into.
Must have a good price in if hand chasing.
Yeah got a casing tool and everything seems fairly straight forward after all you can gauge what your dealing with when you sink your back box in, just worried that if you are going say 5mm into brickwork that there is a chance of cracking the brick?
not proper bricks, but some of the crap they use nowadays has the strength and consistency of weetabix.
We use a Hilti chaser (basically a grinder with 2 disks, with wheels for running up the wall and adjustable depth). Then use a lightweight breaker after that.
Chasing machine with a vacum attatchment....consists of two parallel 4" diamond blades about 25mm apart,cuts a chase deep enough for 20mm conduit...nice and neat. Connected to a standard commercial vac there is virtually no dust,I've used it to cut chases in decorated and furnished rooms. not cheap but if you do a lot it will pay for itself in no time at all.
Cutting boxes in brick nothing touches a line of 6mm holes round the outline and a club hammer and chisel.
Edit...Derek uses the same set-up evidently!
Heard a story once how he knocked a brick too many out in a terraced house and found himself intriducing himself to an elderly couple next door watching TV in t' lounge.
For boxes I draw my box out and put an 18mm drill bit in each corner and inbetween eachcorner. Then I use a single box size chisel on my sds drill and cut it out. If I can't get a good fixing I bond the boxes in. Genuinlly don't see why people bother going by hand in this day and age
I use my makita drill on hammer only with a small chiesel bit in it, might invest in a scutch comb bit though after reading this thread
I had to laugh at the title of this thread ...lol!! I wonder how he thinks back boxes are set into walls?? Also had to have a laugh at the suggestion of dot and dab, ...thought this was an electrical forum!! lol!! You can just imagine telling the customer, ...right i've got all my cables in, so if you can call in the builders now to dot and dab all the wall's, so that i can fit my boxes in!! lol!!!
A good wall chaser with a vacuum attached, will sort out the drops. An SDS with drill to make an outline round the the marked up box position, ...then with the rotary off, and a scutch chisel attachment will normally make short work of the rest.... It only becomes difficult when your up against the old engineering bricks, some those things are like chasing iron!! lol!!
yep....you know when you hit those.....as the chisel point just bounces off em...lol....
Scutch chisel in Bosch SDS for me, I have a disc wall chaser too but you need a GOOD vac to keep up! Pet hate is the hollow blocks, just as you get to box depth you break through into the hollow:mad2:
Has anyone had experience of chasing in brickwork?
Australia
hutch6447,
SPARTYKUS,
