has anyone tried this?? | on ElectriciansForums
Discuss has anyone tried this?? in the Australia area at ElectriciansForums.net
couldn't be arsed to watch it as 8 mins long.
Just a guess are they pushing a high reverse voltage through the cells?
Not sure if it would work, depends why the battery is dead.
It is generally easy to repair, normally just one of the cells is ****ed.
pop open your charged battery.
check the cells one by one, firstly voltage, but if that doesn't point the dead one, use a high current drain device and check for current and voltage drop.
then cut out the dead cells and replace with sub-c size.
simple and can save A LOT of money!
bestofferbuy can get you the cells for cheap (but slow)
Reply to has anyone tried this?? in the Australia area at ElectriciansForums.net
M
trying to fix a Old very Large Tap in a Commercial Kitchen I have a Very old commercial kitchen in my School, it dates originally from the 1950’s...
MrsFixit
M
Went to an Aico skills event at the tail end of January and a presentation by the ECA I think it was, mentioned that the installation PV storage...
    • Informative
