Has anyone used the Quickfix Junction Box : QUICKFIX-JB 3 or QUICKFIX-JB 4 | on ElectriciansForums
Discuss Has anyone used the Quickfix Junction Box : QUICKFIX-JB 3 or QUICKFIX-JB 4 in the Electrical Tools and Products area at ElectriciansForums.net
Birmingham
Hi All.
Anyone got experience/usage of using the Quickfix Junction Box, with the Wago 221 Connectors ?
[ElectriciansForums.net] Has anyone used the Quickfix Junction Box : QUICKFIX-JB 3 or QUICKFIX-JB 4
I have. They are nice, a fair amount of room. Just a bit limited as they only have room for the allocated Wagos inside so a circuit with a loop switched live or any extra cables won't fit.
They are worth having in stock alongside other enclosures. Their best advantage over a grey Wago box is the entry from both ends.
I've used them. Ok, not amazing, as above both end access is good.
Are they able to be used as MF?
The WagoBox lite isn't AFAIK.
Pretty sure it isn't, but it's the perfect thing for slinging above kitchen units for connection to under cabinet lights. Badly terminated choc boxes, with tape in place of cable restraints and to keep the lid closed, needn't be so common in this day and age. Even a complete imbecile should be able to connect Wago 224s inside these little boxes.
Can be used as a BS 5733-MF (Maintenance Free) Accessory only with Wago 221-2411 Inline Connectors and Wago 221-2533 Mounting Carrier. Maintenance Free accessory instructions included with Wagobox Light enclosure must be followed.
Seems like a lot of faff, with needing the special carrier, but good to have the option.
Reply to Has anyone used the Quickfix Junction Box : QUICKFIX-JB 3 or QUICKFIX-JB 4 in the Electrical Tools and Products area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
Hi all, This weekend we have a selection of essential items for Sparky's on offer! Wago 221-412 2 Pole Compact Lever Operated Connector -...
