B
Bridge-Burner
Hi,
I've done my 206 exam but am waiting on the visual inspection before I know if I've passed.
What I'm worried about is that on the SWA part, I used the black as a neutral, wrapped blue tape around the part in the c/u, but forgot to do the same in the actual box part of it. What do you think?
Also, on the paperwork, I think I might have put that I used 3mm cable when in fact it was 2.5? Why I put this I have no idea! Just wasn't thinking straight I guess!
Also there's a small amountof damage to the outer sheath of the 3-core I was using, done when I was hammering in the clips, it's just split the grey part slightly, I can't see the cable inside.
All the insulation testing went fine so I am hoping it will be okay!
