E
electricwoman
I am taking my finnaly exam starting at monday-friday after 2,5 year as an apprentice offshore.
I will be taking the test at a test station onshore. Since its not longer possible to take it offshore.
It scars me and I am starting to get cold feet.
I have 5 days to do the test.
The test is split in two parts
One is the planning part
number two is the wiring and so on.
I cant start on the practicall part before wendesday.
I need to do a full test on the wiring system / full doc on the earth installation .
material list, tool list, calculate IK max/ IK min , making a plan for the working days ,
risiko analyse /hms plan, one line schematic for the inntake ( drawing of the installation with the main cercuite breaker, kwh measurerment) you know.
instrument list (witch instrument I will use)
I know for sure it going to be a typical house wiring on the first task
the other task will be a motor installation. maybe a star triangle faces or something.
Any tips?
I have a MFT 1552 tester
some question about the tester:
since the sensor will be starring when I do the test, maybe he wil ask some questions.
When I turn on the tester it says U3,5 after 5 sec it says 11,3V I figured out the last one has to be the battery power 1,5V*8=12V so I guess there is enough power for my exam and more.
But the U3,5 what is that?
The tester has a manual but its not very good decribed its only a few pages,
When I look at fluke they have a quite big one.
So if anyone have a guidline
What is the diffrent betwheen rcd autotest and manuell?
Can I use RCD auto as a rule for and ordanary wiring system house?
RCD autotest=
RCD manuell 1/2I= I 5I= <I =
LOOP Notrip= PFC= HI = PFC=
mA 10 30 100 300 500 1000 ? is that part of the manuell testing?
Does any one have some easy step to follow?
A pdf file to share , I wil write everything like documentation on my computer
Any tips?
RCD autotest=
