Heat alarm? | on ElectriciansForums
Discuss Heat alarm? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi Guys,
Is a heat alarm required in an existing kitchen that is being altered?
Cheers
Hi Steve, To comply with the Building Regulations Part B, Fire Safety, a heat alarm or detector is not required if the kitchen is separated from the circulation area (eg. hallway) or stairway by a door. If the areas are not separated by a door then a heat alarm or detector would be required. However, as a kitchen is a high fire risk area, in my opinion it is desirable in all circumstances. See EGBR 10.2 and Appendix C for further guidance.
I agreewith MarkisSparkie, as you're not talking about an extension then its not a requirement but I would be recommending one as part of the works.
Reply to Heat alarm? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Yes to 1st question mains wired but radio frequency
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
