heat box wiring - 6 oven heat elements | on ElectriciansForums
Discuss heat box wiring - 6 oven heat elements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
imykh
hi all,
I'm making a heat box with 6 x 1KW oven heat elements inside.
[ElectriciansForums.net] heat box wiring - 6 oven heat elements
I need some guidance with regards to how to wire this box up.
some simple instructions on which wires to use, where to source them etc, would be greatly appreciated.
I would prefer if the box had a single plug which could be connected to the mains BUT I'm told that the standard mains switch won't be suitable as the total power will be 6 x 1KW and the mains will burn out.
The oven will only be used for something like 5 min runs at a time.
6kw = 26A , so a dedicated 6mm circuit on 32Aor 40AMCB is what you need. no way can you put it on a standard 13A plug
thank you for your replies
could you guide me in simple terms as to how I would complete the circuit using the 6mm thick wire?
thanks
Reply to heat box wiring - 6 oven heat elements in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Oh I get that for sure. Here it's not the problem though. The oven is in very good condition, and works well, just the heating element is warped...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
