1shortcircuit
I'm looking for some advice if I may please.
After fitting a Varilight polished chrome 1G 2W 1000 watt dimmer switch I became concerned at how warm the faceplate was getting when the switch was turned to full power. It did seem to reach a peak temperature and not get any hotter but on operating it you were automatically drawn in to thinking of the temperature rather than it's operation being a subcontious effort (If that makes sense? lol)
There are no trapped or warm cables within the back box and the back of the unit is nowhere near the temperature of the faceplate. It functions fine and there is no abnormal smell. (Only one way being used)
This dimmer switch is operating 2 spot lights that each contain 6 gu10 50 watt lamps (600 watt total) The minimum wattage is 200watts and maximum 1000watts so evrything in theory seems fine - Unless there is something that I have simply unaware of. It is the first time I have had to fit a dimmer to lights that draw so much current and want to ensure that I am able to go to sleep and not learn of a building that has burnt to the ground due to the faceplate getting so warm.
I'm aware that the device will create heat and this will need to go somewhere but I just want to ease this concern.
Has anyone else had issues with these types of units or is it in fact perfectly normal just like the very slight buzzing that the manufacturers explain too?
All help is very much appreciated
:thumbsup
:thumbsup
