Heat detector in kitchen notifiable? | on ElectriciansForums
Discuss Heat detector in kitchen notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
UK
Someone I know requires a heat detector to be fitted in their kitchen because they are renting the house out. It would fit onto the lighting circuit.
Is this notifiable?
Also, emergency lighting, connected to the existing lighting circuit, is it notifiable? This would be in hallways etc.
Any work carried out in a kitchen is notifiable, even minor works, so heat detector needs to be notified.
Emergency lighting is as Telectrix said above.
Be carefull fitting just a heat detector,I believe they should not be used, without being linked to other types of detector.ionisation or optical
if they already have smoke detectors, you could just link in with a 3core.
But that would still be notifiable?
It's the local council that have said the work has to be done, I'm sure they'll be checking everything!
Along with the fire extinguishers that have to be fitted and the emergency lighting!
Bit of a joke just to rent out a house!
so, speak to the local council. ask them their requirements as regards notification.
Reply to Heat detector in kitchen notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Thanks all. Sounds like I hadn’t completely missed the point on what Part P needs at least. I’m not so much worried about a knock on the door as...
