This is an RSS feed of thread: Heat Exchanger with AGA and heat pump
Content of the thread: Hi All I have a client asking whether they can still use the AGA to heat rads once the air source heat pump is in. I think it is possible using a heat exchanger so the low pressure AGA and high pressure heat pump systems don't connect. I've seen it done on biomass systems but wonder what the implications are with heat pump legislation
Heat Exchanger with AGA and heat pump to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
