heat from floursecent tubes | on ElectriciansForums
Discuss heat from floursecent tubes in the UK Electrical Forum area at ElectriciansForums.net
E
Eddiesparks
installing some 2x 35w flourescent fittings in an office and they are clearly designed for entry thru the ceiling straight into the terminals but the old ones were wired in singles in conduit so have drilled 20mm holes in lights for side feeding etc. One of them in particular has got me a bit worried because the fittings have the tubes inside them and the only cover is the diffuser and the way it is wired presently means that the pvc singles are well close to the tubes. I couldn't find any other way to get to the terminals. I know the cables can withstand 70c (although obv CCC gets loads lower a this temp) and fluorescents are not nearly as warm as incandescent lamps but slightly worried about this. Should I get back there and try and sort something. Maybe heatproof sleeving?!?! Any bright ideas? Thanks a lot peoples.
What about some heat proof sleeving :leaving::leaving::leaving::leaving::leaving::leaving:
get these guys to help. they know all about flourescents.
[ElectriciansForums.net] heat from floursecent tubes
If you're worried some standard heat shrink over the wiring would be fine. There's no way the tubes will ever get to 70 degrees C. The only part of a fluorescent that might is if it's got old wire-wound ballasts which get hot when the tube reaches its end of life and doesn't fully strike. New ballasts all have safety built in to stop this so if it's a new fitting you've got nothing to worry about.
Reply to heat from floursecent tubes in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
OK, so as a quick update to this. I found a junction box (Wago Abox SL-2,5/4² # 80680701, see image) that looks like a great fit for my needs...
4K
I do a lot of dimming with large residential systems and they are largely triac-based. They work well and are almost always LED-based these days...
G
I wouldn't recommend globe lamps or any other enclosed vertically aligned batten style of light for that matter. With the bulb's metal parts...
Greg:
G
