Heat loss in cable | on ElectriciansForums
Discuss Heat loss in cable in the Australia area at ElectriciansForums.net
J
joner1
Hi Guys, first of all sorry if this is posted in wrong section.
I am doing a building services design course at southbank university and have an assignment on cable sizing for a submain, I need to calculate the heatloss in this cable.
As i remember heat loss is calculated using P=I*R,
Do i have to calculate the resistance of the Line AND Neutral conductor for this calculation or is it just the resistance of the Line conductor?
Many thanks in advance
Thanks for the replies everyone, Malcolm, thanks for clearing that up(I realise i put multiply instead of ²), i seem to remeber years ago being taught that I²R losses were heat losses, but i've never had to calculate heat loss in a cable before so didn't know if it applied.
Telectrix, I thought that it was L+N too but with all the other replies i'm confused now :)
Reply to Heat loss in cable in the Australia area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
