Heat pump hot water cylinders Has anyone fit the hot water cylinders with a little heat pump on the top that has ducts to bring inside and outside air in to the unit. Piping up wise is it just the same as a normal direct cylinder?
Heat pump hot water cylinders to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
